67 to 70 F350 Driver's side Inner Tie Rod End
kid
Post by kid »
I can not find one from anybody. Does anyone know if a F250 or some other year inner tie rod will fit?
Complete front end rebuild going on here. Brake drums, wheel cylinders, king pins, Steering box, Drag link, outer tie rod end, bushings and shocks all at once. Well, over six months with the front end in the air. and the Inner tie Rod end is holding me up.
Leadfoot
re: 67 to 70 F350 Driver's side Inner Tie Rod End
Post by Leadfoot »
on my 1970 f350 I use the 1977 inner tie rod uap pt # ncp2692238
i
WHAT ?
kid
Post by kid »
Thank You, I just got a 77 inner and adjusting sleeve. Too bad I could not return my outer is cost me 96. It turns out that they changed the inner rod and outer rod lengths but the whole assembly is the same length. Mine will be 1/2" shorter because of the 69 outer and the rest being a 77.
